  3. OVAL OBLONG DRILL SLOT NC-ROUTE
  • Replies 9
  • Subscribers 167
  • Views 22353
asese
asese over 12 years ago
I am trying to find a way for producing oblong drill holes. Even if I design an oblong pad and then create the artwork files, i cant read the nc-route file in CAM350 and oblong drills dont apeear on drill layer file(.drl). I exported OBD++ file but I need to obtain .art files for PCB house. Is there a way to produce oval drills or convert OBD++ files into .art files?
Thanks in advance.
  • joma
    joma over 12 years ago
     If I understand the question, it seems that you need to create a padstack and select Oval Slot for the hole type.
    Menu > Tools > Padstack > Modify Library Padstack... Choose and existing padstack and modify it then save
    under a new name. The slot appears in your drill legend, you then need to create the NC Route file.
  • asese
    Thanks for your reply joma,
    actually i already created the oval slot and drill legend but when i create the nc-route file i cant open it in CAM350, it returns an error like "there is no header". i can export the data with ODB++ but i need to convert it into .art file or get rid of this error in nc-route. I think there is a problem with my nc-route file. I cant find out what it could be.
  • joma
    For comparison I have created an nc slot file which you can look at for differences in your setup. On the other hand you may need to change something in your CAM 350 but as I do not have that software I can not say.
    As for working with gerber files you could simply draw and dimension the slot in your drill drawing and let the board manufacturer create it.The drawing could be saved as gerber or pdf. Its a possible workaround until you can get your nc setup working.
    slot.zip
  • asese
    I couldnt view it also but i think you are right, it is caused by CAM350 viewer. i have send the .rou file to manufacturer and there appears the slot drills. Just creating the .rou file with the right parameters is enough for slot drills. Some viewers cant load the file but it is not problem.
    Thanks a lot.
  • steve
    steve over 12 years ago
    Before 16.6 you needed to create a ncroutebits.txt that listed the nc route details. Since 16.6 this is created automatically. Take a look at:-
    http://www.parallel-systems.co.uk/images/PDF/slots_pcb_editor.pdf
