  3. show grid settings
  • Replies 9
  • Subscribers 166
  • Views 21064
show grid settings
docb
docb over 11 years ago
Is there a way to see current grid settings on the screen, or do I need to go to "settings/define grid" just to see current?
  • chads108
    chads108 over 11 years ago
     Sorry, only one attachment at a time allowed apparently.  Here is the second one.
     Chad
    Dynamic_Menus.zip
  • ScottCad
    ScottCad over 11 years ago
    Strange result.
    There are two parts to make this work. Add this to your env file. It will use the lower case g key to cycle through various
    grid sizes.
    funckey g 'settoggle gridvalue 100 50 25 12.5 5; replay set-grid $gridvalue;echo grid = $gridvalue'
    The second part is a script. It needs to be placed in the directory where cadence can read scripts from.
    Save it as set-grid.scr
    Verify that your "Scriptpath" folder under user preferences >Paths>Config is where you have saved set-grid.scr
    otherwise it wont work
    scriptmode +invisible
    setwindow pcb
    define grid
    setwindow form.grid
    FORM grid non_etch non_etch_x_grids $gridvalue
    FORM grid non_etch non_etch_y_grids $gridvalue
    FORM grid all_etch all_etch_x_grids $gridvalue
    FORM grid all_etch all_etch_y_grids $gridvalue
    FORM grid done
    It works for me in 16.6
    Thanks Scott
  • docb
     Got it. I was missing crcuial carriage returns. Thanks.
    (I still wish there was a way to see the grid setting without changing)
  • eric03
    eric03 over 7 years ago in reply to ScottCad
    Great Scott! I lost this command on my env files when my laptop is formatted. I just had a question also on this, can the grids be forward and backward on the values?
    For example i set it to 100 then 50 and back to 100, do i need to go through all of the declared values before i get back to 100?
