  3. How to flip PCB?
  • Views 20574
How to flip PCB?
Leeya
Leeya over 11 years ago
Hi, Have a very simple question, I am doing a two layer board, with both side component. I want flip bottom to top,also with the component flip with board in allegro. I know there is a right left flip function , but haven't see bottom top flip. How to flip the board?
  • redwire
    redwire over 11 years ago
     There is no vertical flip...
  • mcatramb91
    mcatramb91 over 11 years ago
    One trick that I learned to accomplish this was to create a Placement Replicate of the circuitry.  Once it is a Place Replicate group you have the ability to Move / Mirror / Rotate it as one unit (group).  Once it is on your cursor during Move selecting Mirror from the Right Mouse Button (RMB) menu to mirror everything from top to bottom vertically, so if J1 was on the Left on the Top it will be on the Right on the Bottom.
    Here are the steps to create a Placement Replicate group:
    - Go into Placement Edit Application Mode (RMB in the background; Application > Placement Edit)
    - Select Symbols in the Find Filter and window the components/circuitry
    - RMB over one of the highlight symbols and select "Place replicate create"
    - It should highlight all the Clines/Vias/Shapes attached to the components.
    - You can now select/unselect any additional etch items that were not highlighted, then RMB Done.
            - NOTE: In order for a Cline/Via/Shape to be selected it must have a Net Name with a path back to a Pin.
    - Select the origin point for the Place Replicate group and save it to a local file.
    - You Done!   Now select Groups in the Find Filter and you can move the circuitry as one Group which gives you access to RMB Mirror
    I have frequently used Place Replicate to replicate circuitry on many designs, with the added flexibility to mirror the entire groups from one side of the board to the other. You should have access to the Placement Replicate functionality using an OrCAD PCB Designer Professional license up thru the Cadence Allegro products.
    Hope this helps,
    Mike Catrambone
  • Leeya
    Very good idea, I am trying it
    Thanks Mike
  • Vic Tor
    Vic Tor over 7 years ago in reply to mcatramb91
    Just want to  say Thanks on this useful information. Worked great!
