  3. Step Package mapping option not finding in setup menu
  • Replies 9
  • Views 22430
step package
step package over 11 years ago
Step Package  mapping option not finding in setup menu in allegro 16.6 P004.
Plaese help me how to enable it.
  • chads108
    chads108 over 11 years ago
     STEP mapping was added in a later release.  You are currently running the base release P004 (about 32 updates behind).  I would recommend getting the latest release installed.  STEP mapping will then be available in the menus.
    Chad
  • Wild
    Wild over 10 years ago
    In Allegro PCB Designer (board editor): I do have the Step Package Mapping in the toolbar pull down under the Setup menu option. I am running 16.6 S039 However I do have this option in the Package editor. Any ideas how to run this mapper in the board editor?
  • chads108
    chads108 over 10 years ago
    It runs the same in both editors.  Might have to set your steppath in User Preferences => Paths
  • Wild
    Thanks for the reply. I have the path setup in User Preferences. I don't have the menu select in the PCB editor, But I have the menu select in the package editor.
  • steve
    steve over 10 years ago
    Are you running any custom menus ? Check your menupath setting in User Preferences, make sure the default one from C:\Cadence\SPB_16.6\share\pcb\text\cuimenus is at the top. Your custom menu will not have these new options.
