  3. 2560 x 1440 Resolution monitor and capture/pcb editor resolution...
  • Subscribers 166
  • Views 9009
2560 x 1440 Resolution monitor and capture/pcb editor resolution help
cadSmith
cadSmith over 11 years ago
 I recently purchased a laptop with a really high resolution (2560x1440).   Most of windows type programs scale nicely but orcad and pcb editor do not.  All my icons and windows are very tiny which I work through by zooming in quite a bit.
Unfortunately the step package mapping dialogue window in pcb editor has the opposite problem.  It's very large and the bottom buttons (apply, ok, cancel) do not appear on the screen.  The window can be resized but the contents within the window borders do not scale so no matter what dimensions I stretch the window to I can not see the bottom area where the buttons are located.
 A scroll bar would really help the issue but the ability to change the resolution of dialogues and icons within the pcb editor program itself would be great.  Does anyone know how to go about configuring the software to work with higher resolution displays?
FYI:
I Changed the windows resultion down to 1920x1280 and even down to 1024x768 did not give me more step mapping dialogue visibility.
  • JFeyler
    JFeyler over 9 years ago
    Here's my findings: To run OrCad v17.2, the optimal resolution for the primary display is 1600x900 at 125%, and for the secondary display, max resolution at 250%. The primary display resolution sets the appearance of the OrCad UI for both displays.
