  3. OrCAD Capture crashes on start up
  • Replies 8
  • Subscribers 168
  • Views 37869
mwaskett
mwaskett over 11 years ago
Hi All,
I'm having trouble with OrCAD capture v16.6 (latest hotfix), in which the program refuses to open without crashing instantly. I'm not getting any error messages, it just freezes when I open it and doesn't respond. It will not close unless I end the task from task manager. This started happening a couple of days ago, but no new programs have been installed recently so it can't be that that's causing it. I've uninstalled any updates that have been installed since it started happening as well.
I'm using Windows 8.1, and I've been able to use the program fine up until a couple of days ago.
Any ideas on why this is happening, and what I can do to fix it?
  • Haui
    Haui over 10 years ago
    The described procedure above has no affect. Orcad still hang up when started. Im my registry there was no entry like \CaptureWorkSpace\ . Could this maybe be the problem. Thanks for yor help.
  • dashing BGH
    dashing BGH over 10 years ago
    sir, i have similar problem with Virtuoso IC514 in fedora....any suggestions?? cadence crashed due to power failure.....then on, its unable to load ....it reaches upto schematic window and then crashes on clicking.
  • Lepi
    Lepi over 10 years ago
    Please, I have the same problem and do not see that problem is solved? Did you solved it somehow? Tnx
