  3. How to arrange my board design based on the A4 page siz...
  • Replies 23
  • Views 26708
How to arrange my board design based on the A4 page size
Andrew2
Andrew2 over 11 years ago
Hello:
I wanna arrange ten board designs on A4 page.
How to adjust the board design coordinate and put the ten designs on the same page in the pcb editor.
  • Andrew2
    Eliver Castro: Hello, I do not wanna make the Module instance name as prefix name. I have to give a Module instance name before I add a board module. This Module instance name will become a prefix name in front of the originally component name. for example, R1 will become G_R1("G" is the module instance name I give). Is there any way to shield or delete this name? Thank you for your attention.
  • elivs
    elivs over 11 years ago
    Good day.
    As from your query there is no other way to delete the prefix name since every net and component must have unique identity in a single board data for logical connections otherwise it will create errors.
    I think your problem now is the componen's silk and assembly name to display?
    If that is the problem, there are other ways to display the these refdes same as from the base data.
  • Andrew2
    Eliver Castro:
    Yes, you are right,
    My problem is how to display silk and assembly name identical with base data.
    Could you tell me how to do this?
  • chads108
    chads108 over 11 years ago
    I will throw in my 2 cents worth.  If this is a simple step and repeat of the same circuit, it is a lot less work and probably easier for everyone involved if you let the board shop do the step and repeat.  We have always done that here.  We supply the board outline with the step and repeat dimensions, any break-offs, mouse-bites, etc. and they will do the rest.
  • Andrew2
    chads 108: Thank you for your prompt reply. Because my boss wanna cost as less money as possible, so I could only do my best to achieve his request.
