  3. Problems implementing master capture.ini
  • Replies 7
  • Subscribers 168
  • Views 17859
scottm7
scottm7 over 10 years ago
I'm running Allegro Design Entry CIS v16.6-S039 and having problems implementing a master capture.ini file.  I downloaded the CIS admin tool and used SetMasterIniPath.exe.  I've verified that this added a registry key to HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Cadence Design Systems\MasterSettingsFile.  Note that this is a different location than in the documentation which specifies HKEY_LOCAL_MACHINE\SOFTWARE\Cadence Design Systems\MasterSettingsFile which I've also manually entered into the registry.
My master capture.ini file currently only has a single entry while I experiment as seen below:
[Part Management]
Configuration File=J:\Configuration_Files\CIP-E V5.0 CIS DB.DBC
I expect this entry to replace the existing entry in my capture.ini file located at C:\Users\<username>\AppData\Roaming\SPB_Data\cdssetup\OrCAD_Capture\16.6.0 but it does not.  Can anyone help me debug what is wrong?
  • scottm7
    Thank you very much.  This was extremely helpful.
  • IanK
    IanK over 8 years ago
    The fact you don't seem to have opened any queries relating to database issues suggests the replication work went well.
