  3. Cannot Place part manually in Orcad 16.6 Pcb editor
  • Replies 35
  • Subscribers 168
  • Views 35680
Deep7086
Deep7086 over 10 years ago
{NEW TO ORCAD]
I can netlist (with the usual renaming warnings) and open the netlist in Orcad PCB. I get a (correct) list of parts when I go to Place/Manually - but there's no Quickview preview and I can't place anything. I can check the parts but then when I hit ok Its just blank. There should be an error message to hint what's wrong - but I don't know where to look (netrev.lst is "clean" with no error/oversight/warning detected). Very, very frustrating!
After netlist i can see a new.brd file but its just waste. I cant place anything. Plz i need to get done with a project within 2 weeks and this thing is just eating me.
Any Instant help would be appreciated.
Deep.
  • Deep7086
    Thank you Dave
    Now the quick place works fine..but manual place is not working...i checked the path its correct.. I dont know whats wrong.
  • eDave
    eDave over 10 years ago
    Have you ticked "Library" in the Advanced Settings tab?
  • Deep7086
    Yes I did still I am not able to place manually. The command window says placing R13/resistor on top when the select the resistor to  place manually, but I don't see anything.
  • Deep7086
    Yes now it works fine thank you for your help. I must click hide after the part. I did it wrong all this time
  • Deep7086
    I have a new question...how do i update board size ? i have to expand the board to 100 mils in width.
