  3. move groups
  • Replies 7
  • Subscribers 168
  • Views 14840
move groups
docb
docb over 9 years ago
I have a section of the board all routed, and I'd like to drag that over some, bringing all the routing between the components along. It seems like I need to disconnect traces going to the section, then do a move.
Its seems like 'ripup etch' is the best mode to use.
Is there a better way?
  • steve
    steve over 9 years ago
    Take a look at:- http://www.parallel-systems.co.uk/images/PDF/Group_Rotate.pdf It's set for group rotate but the principle is the same. There are more "modern" ways simply using a group select but this does work.
  • docb
    Excellent. This was very helpful. Thanks very much.
