  3. Altium Designer 16 to Allegro Design Entry CIS
  • Subscribers 168
  • Views 15174
PhilH
PhilH over 9 years ago
I'm trying to convert an Altium Designer 16 schematic to Allegro Design Entry CIS so I can do the PCB layout in Allegro.
I spent most of the day yesterday on the phone with tech support at EMA with no luck.
We saved all Altium schematic sheets to ASCII file then used the "import Altium schematic" from CIS.
The Altium schematic is a hierarchical schematic and it seems the CIS importer is choking on some of the "harness" entities on he schematic.
We removed some of the "harness" entities and ultimately got the translator to create a dsn file, but when it was opened, it was obviously corrupted.
Has anyone successfully imported an Altium schematic into CIS using the Altium importer?
Any help would be appreciated.
  • UlfK
    UlfK over 9 years ago
    I have experienced the same thing both with Altium Schematics and Layouts. It does not work, and when trying to translate an Altium layout saved in binary format, the translator does not exit "gracefully" with an error message. I have filed a service request with Cadence almost a month ago.
