  3. Pspice error-Node is floating
  • Views 23246
imdc
imdc over 8 years ago
while simulation in pspice m getting these error,what can be the for these error??
ERROR(ORPSIM-15142): Node 2_V_SAFE is floating
ERROR(ORPSIM-15142): Node 2_V_POS is floating
ERROR(ORPSIM-15142): Node 2_N16777364 is floating
ERROR(ORPSIM-15142): Node 2_N16777258 is floating
ERROR(ORPSIM-15142): Node 2_N16777343 is floating
ERROR(ORPSIM-15142): Node 2_N16777844 is floating
ERROR(ORPSIM-15142): Node 2_N16777353 is floating
ERROR(ORPSIM-15142): Node 1_POWER+ is floating
ERROR(ORPSIM-15142): Node 1_N16777399 is floating
ERROR(ORPSIM-15142): Node GND is floating
ERROR(ORPSIM-15142): Node N17178813 is floating
ERROR(ORPSIM-15142): Node 1_GND_D is floating
ERROR(ORPSIM-15142): Node 3_N16703541 is floating
ERROR(ORPSIM-15142): Node 3_VDD_D_3V3 is floating
ERROR(ORPSIM-15142): Node 3_GND_D is floating
ERROR(ORPSIM-15142): Node 6_N00336 is floating
ERROR(ORPSIM-15142): Node 6_N00362 is floating
ERROR(ORPSIM-15142): Node 6_GND_D is floating
ERROR(ORPSIM-15142): Node 2_GND_D is floating
ERROR(ORPSIM-15142): Node 2_N16781550 is floating
ERROR(ORPSIM-15142): Node N17178733 is floating
ERROR(ORPSIM-15142): Node N17178831 is floating
ERROR(ORPSIM-15142): Node 1_V_POS is floating
ERROR(ORPSIM-15142): Node X_1_RV100.200 is floating
ERROR(ORPSIM-15142): Node X_1_RV100.100 is floating
ERROR(ORPSIM-15142): Node X_1_RV100.300 is floating
ERROR(ORPSIM-15142): Node X_1_RV100.400 is floating
ERROR(ORPSIM-15142): Node X_1_D102.3 is floating
ERROR(ORPSIM-15142): Node X_1_D102.4 is floating
ERROR(ORPSIM-15142): Node X_1_D102.5 is floating
ERROR(ORPSIM-15142): Node X_1_D102.6 is floating
ERROR(ORPSIM-15142): Node X_1_D102.7 is floating
ERROR(ORPSIM-15142): Node X_1_D102.8 is floating
ERROR(ORPSIM-15142): Node X_1_D102.9 is floating
ERROR(ORPSIM-15142): Node X_1_D102.10 is floating
ERROR(ORPSIM-15142): Node X_1_D102.11 is floating
ERROR(ORPSIM-15142): Node X_1_D102.12 is floating
ERROR(ORPSIM-15142): Node X_1_D102.13 is floating
ERROR(ORPSIM-15142): Node X_1_D102.14 is floating
ERROR(ORPSIM-15142): Node X_1_D102.15 is floating
ERROR(ORPSIM-15142): Node X_1_D102.16 is floating
ERROR(ORPSIM-15142): Node X_1_D102.17 is floating
ERROR(ORPSIM-15142): Node X_1_D102.18 is floating
ERROR(ORPSIM-15142): Node X_1_D102.19 is floating
ERROR(ORPSIM-15142): Node X_1_D102.20 is floating
ERROR(ORPSIM-15142): Node X_1_D102.21 is floating
ERROR(ORPSIM-15142): Node X_1_D102.22 is floating
ERROR(ORPSIM-15142): Node X_1_D102.23 is floating
ERROR(ORPSIM-15142): Node X_1_D102.24 is floating
ERROR(ORPSIM-15142): Node X_1_D102.25 is floating
ERROR(ORPSIM-15142): Node X_1_D102.26 is floating
ERROR(ORPSIM-15142): Node X_1_D102.27 is floating
ERROR(ORPSIM-15142): Node X_1_D102.28 is floating
ERROR(ORPSIM-15142): Node X_1_D102.29 is floating
ERROR(ORPSIM-15142): Node X_1_D102.30 is floating
ERROR(ORPSIM-15142): Node X_1_D102.31 is floating
ERROR(ORPSIM-15142): Node X_1_D102.32 is floating
ERROR(ORPSIM-15142): Node X_1_D102.33 is floating
ERROR(ORPSIM-15142): Node X_1_D102.34 is floating
ERROR(ORPSIM-15142): Node X_1_D102.35 is floating
ERROR(ORPSIM-15142): Node X_1_D102.36 is floating
ERROR(ORPSIM-15142): Node X_1_D102.37 is floating
ERROR(ORPSIM-15142): Node X_1_D102.38 is floating
ERROR(ORPSIM-15142): Node X_1_D102.39 is floating
ERROR(ORPSIM-15142): Node X_1_D102.40 is floating
ERROR(ORPSIM-15142): Node X_1_D102.41 is floating
ERROR(ORPSIM-15142): Node X_1_D101.3 is floating
ERROR(ORPSIM-15142): Node X_1_D101.4 is floating
ERROR(ORPSIM-15142): Node X_1_D101.5 is floating
ERROR(ORPSIM-15142): Node X_1_D101.6 is floating
ERROR(ORPSIM-15142): Node X_1_D101.7 is floating
ERROR(ORPSIM-15142): Node X_1_D101.8 is floating
ERROR(ORPSIM-15142): Node X_1_D101.9 is floating
ERROR(ORPSIM-15142): Node X_1_D101.10 is floating
ERROR(ORPSIM-15142): Node X_1_D101.11 is floating
ERROR(ORPSIM-15142): Node X_1_D101.12 is floating
ERROR(ORPSIM-15142): Node X_1_D101.13 is floating
ERROR(ORPSIM-15142): Node X_1_D101.14 is floating
ERROR(ORPSIM-15142): Node X_1_D101.15 is floating
ERROR(ORPSIM-15142): Node X_1_D101.16 is floating
ERROR(ORPSIM-15142): Node X_1_D101.17 is floating
ERROR(ORPSIM-15142): Node X_1_D101.18 is floating
ERROR(ORPSIM-15142): Node X_1_D101.19 is floating
ERROR(ORPSIM-15142): Node X_1_D101.20 is floating
ERROR(ORPSIM-15142): Node X_1_D101.21 is floating
ERROR(ORPSIM-15142): Node X_1_D101.22 is floating
ERROR(ORPSIM-15142): Node X_1_D101.23 is floating
ERROR(ORPSIM-15142): Node X_1_D101.24 is floating
ERROR(ORPSIM-15142): Node X_1_D101.25 is floating
ERROR(ORPSIM-15142): Node X_1_D101.26 is floating
ERROR(ORPSIM-15142): Node X_1_D101.27 is floating
ERROR(ORPSIM-15142): Node X_1_D101.28 is floating
ERROR(ORPSIM-15142): Node X_1_D101.29 is floating
ERROR(ORPSIM-15142): Node X_1_D101.30 is floating
ERROR(ORPSIM-15142): Node X_1_D101.31 is floating
ERROR(ORPSIM-15142): Node X_1_D101.32 is floating
ERROR(ORPSIM-15142): Node X_1_D101.33 is floating
ERROR(ORPSIM-15142): Node X_1_D101.34 is floating
ERROR(ORPSIM-15142): Node X_1_D101.35 is floating
ERROR(ORPSIM-15142): Node X_1_D101.36 is floating
ERROR(ORPSIM-15142): Node X_1_D101.37 is floating
ERROR(ORPSIM-15142): Node X_1_D101.38 is floating
ERROR(ORPSIM-15142): Node X_1_D101.39 is floating
ERROR(ORPSIM-15142): Node X_1_D101.40 is floating
ERROR(ORPSIM-15142): Node X_1_D101.41 is floating
ERROR(ORPSIM-15142): Node N17187705 is floating
ERROR(ORPSIM-15142): Node 1_VCC_D is floating
ERROR(ORPSIM-15142): Node 3_N16703831 is floating
ERROR(ORPSIM-15142): Node 3_N16703691 is floating
ERROR(ORPSIM-15142): Node 3_VCC_D is floating
ERROR(ORPSIM-15142): Node 3_VCC_A is floating
ERROR(ORPSIM-15142): Node N17189905 is floating
ERROR(ORPSIM-15142): Node 3_V_SAFE is floating
ERROR(ORPSIM-15142): Node 13_N16759442 is floating
ERROR(ORPSIM-15142): Node 13_VCC_D is floating
ERROR(ORPSIM-15142): Node N17205574 is floating
ERROR(ORPSIM-15142): Node TX is floating
ERROR(ORPSIM-15142): Node N17205565 is floating
ERROR(ORPSIM-15142): Node 7_N00157 is floating
ERROR(ORPSIM-15142): Node 7_N00187 is floating
ERROR(ORPSIM-15142): Node 8_VCC_A is floating
ERROR(ORPSIM-15142): Node 8_GND_D is floating
ERROR(ORPSIM-15142): Node 9_VCC_A is floating
ERROR(ORPSIM-15142): Node 9_GND_D is floating
ERROR(ORPSIM-15142): Node 10_N16775406 is floating
ERROR(ORPSIM-15142): Node RX is floating
ERROR(ORPSIM-15142): Node 10_N16775068 is floating
ERROR(ORPSIM-15142): Node 10_N16775254 is floating
ERROR(ORPSIM-15142): Node VREF is floating
ERROR(ORPSIM-15142): Node N17186121 is floating
ERROR(ORPSIM-15142): Node 10_N16775028 is floating
ERROR(ORPSIM-15142): Node N17186124 is floating
ERROR(ORPSIM-15142): Node 10_N16775044 is floating
ERROR(ORPSIM-15142): Node 10_DIFF is floating
ERROR(ORPSIM-15142): Node 10_N16774990 is floating
ERROR(ORPSIM-15142): Node 10_FIL is floating
ERROR(ORPSIM-15142): Node 10_VCC_A is floating
ERROR(ORPSIM-15142): Node 10_GND_D is floating
ERROR(ORPSIM-15142): Node 11_XTAL1_S is floating
ERROR(ORPSIM-15142): Node 11_GND_D is floating
ERROR(ORPSIM-15142): Node 11_XTAL2_S is floating
ERROR(ORPSIM-15142): Node 11_VCC_A is floating
ERROR(ORPSIM-15142): Node 11_VCC_D is floating
ERROR(ORPSIM-15142): Node 11_N16794785 is floating
ERROR(ORPSIM-15142): Node 11_N16801115 is floating
ERROR(ORPSIM-15142): Node 11_N16793520 is floating
ERROR(ORPSIM-15142): Node N17190141 is floating
ERROR(ORPSIM-15142): Node 11_N16793478 is floating
ERROR(ORPSIM-15142): Node N17190139 is floating
ERROR(ORPSIM-15142): Node 11_N16793499 is floating
ERROR(ORPSIM-15142): Node N17190145 is floating
ERROR(ORPSIM-15142): Node 11_N16793510 is floating
ERROR(ORPSIM-15142): Node 11_N16793476 is floating
ERROR(ORPSIM-15142): Node 11_N16816169 is floating
ERROR(ORPSIM-15142): Node N17182452 is floating
ERROR(ORPSIM-15142): Node 11_N16814002 is floating
ERROR(ORPSIM-15142): Node 4_XTAL1_M is floating
ERROR(ORPSIM-15142): Node 4_GND_D is floating
ERROR(ORPSIM-15142): Node 4_XTAL2_M is floating
ERROR(ORPSIM-15142): Node 4_VCC_A is floating
ERROR(ORPSIM-15142): Node 4_N16811688 is floating
ERROR(ORPSIM-15142): Node 4_VCC_D is floating
ERROR(ORPSIM-15142): Node 4_N16812330 is floating
ERROR(ORPSIM-15142): Node 4_N16827900 is floating
ERROR(ORPSIM-15142): Node 12_VCC_D is floating
ERROR(ORPSIM-15142): Node 12_GND_D is floating
ERROR(ORPSIM-15142): Node N17180848 is floating
ERROR(ORPSIM-15142): Node 12_N16764073 is floating
ERROR(ORPSIM-15142): Node 5_VCC_D is floating
ERROR(ORPSIM-15142): Node 5_GND_D is floating
ERROR(ORPSIM-15142): Node N17190068 is floating
ERROR(ORPSIM-15142): Node 5_N16764091 is floating
ERROR(ORPSIM-15142): Node 14-EEPROM_VCC_D is floating
ERROR(ORPSIM-15142): Node 14-EEPROM_GND_D is floating
ERROR(ORPSIM-15142): Node SCL is floating
ERROR(ORPSIM-15142): Node SDA is floating
ERROR(ORPSIM-15142): Node VCC_A is floating
ERROR(ORPSIM-15142): Node 15_GND_D is floating
ERROR(ORPSIM-15142): Node N17201904 is floating
ERROR(ORPSIM-15142): Node X_7_L700.X1.31 is floating
ERROR(ORPSIM-15142): Node X_8_L5.X1.31 is floating
  • oldmouldy
    oldmouldy over 8 years ago
    You are missing a "0" symbol. All circuit nodes in a PSpice (SPICE) circuit must have a DC path to "0". There is a DRC for this in later versions that gets flagged when the netlist gets created. Since you have a GND net, I suspect that you placed a generic GND symbol and not a PSpice specific "0" symbol.
