  3. Allegro 17.2 backdrill solder mask export to GERBER
  • Views 16607
VECTORT
VECTORT over 8 years ago
I have created design with backdrills and right now I have an issue with exporting soldermask do gerber files.
For via solder opening there is a layer: VIA CLASS/SOLDERMASK_TOP and VIA CLASS/SOLDERMASK_BOTTOM
And that works perfectly but when backdrills are created the solder mask opening is set in layer named BACKDRILL_SOLDERMASK.
But this layer I can be see only in "PAD Editor" in "Mask Layers" tab.
There I can see SOLDERMASK_TOP: none SOLDERMASK_BOTTOM: none and in BACKDRILL_SOLDERMASK: Circle 0.55
And I have no idea how to export it to GERBER files because there is no such layer in Artwork to be selected.
Thanks in advance for any help.
  • VECTORT
    Thank you
    That worked.
    The soldermask top and bottom should be different than 'none'
