  3. PCB 17.2 Step Mapping troubles
  • Replies 9
  • Subscribers 166
  • Views 14401
PIPE
PIPE over 7 years ago
Hi i have some Troubles to map some 3D Step files.
Here a view Samples.Step.zip
Regards
Peter
  • PIPE
    PIPE over 7 years ago in reply to steve
    Hi Steve,
    what have you done that you can see the step from my capacitor whithin the step mapping Dialog. have you a tool to repair something? what the exact steps to map this.
    Peter
  • steve
    steve over 7 years ago in reply to PIPE
    Nothing - There is an overlay button that you need to press but this could also be related to an older version of the software, what exact version are you running from Help - About. The latest for 16.6 is S105 so if you don't have that get it from http://support.cadence.com
  • PIPE
    Wow, that is really bad. on my System this do not work.
    i have installed 16.6 with 105 and 17.2 with 33 on both Installation i have no way to Import this step.
    i have a lot of experience with this easy stuff. my pcb has around 100 footprint with steps but not for this the capacitors.
    Really annoying
    Thanks for your help.
    Peter
  • steve
    That it odd - I have resaved the step model using FreeCAD so see if this one workssteve.zip
