  3. Cadence Orcad/Allegro SPB 17.2 Release
  • Replies 11
  • Subscribers 168
  • Views 15515
growingmind
growingmind over 6 years ago
Excuse my question, I am new to PCB Design.
Is the Cadence SPB / OrCAD 17.2 release one that includes BOTH OrCAD and Allegro of Cadence PCB software ?
I want to use Allegro not ORCAD.
I would like to purchase Allegro but I only see this Cadence/OrCAD 17.2 SPB release on the Cadence website.
Can someone let me know - if I purchase this SPB release do I get BOTH OrCAD and Allegro ?
Thank you.
  • redwire
    redwire over 6 years ago in reply to growingmind
    Yep.  There is a feature matrix that explains the nuances between the license levels but I suspect the base level OrCAD tools will do what you need.
  • steve
    steve over 6 years ago in reply to Robert Finley
    Check this Matrix out which gives detail as to what you get / don't get in each level:- www.parallel-systems.co.uk/matrix and just to correct you OrCAD Std and Pro get IDX import and export....
  • Robert Finley
    Robert Finley over 6 years ago in reply to steve
    Thank you for the Parallel-systems matrix..  It's been a while since I've used Orcad layout.
    Can Orcad Pro import GDS II data like Allegro?
  • steve
    That would be a No.
  • growingmind
    growingmind over 6 years ago in reply to redwire
    Well, I am actually looking for RF and Microwave capabilities at greater than GHz frequencies - so I think or I was told that OrCAD is not as good as Allegro for that ?
    Is that correct ?  Allegro is the better option for high speed/RF//Microwave PCB layout.  Is that not correct ?
