  3. 3D Viewer don't works
  • Replies 7
  • Views 4321
NicoDD
NicoDD over 6 years ago
Hi all,
when I select "DISPLAY --> 3D VIEW" I receive in the command window the message:
Command not found: 3d viewer
How can I check to solve this error?
Version: 17.2-2016 S051
OS: Windows 7 - 64bit
Thank you
  • Wild
    Wild over 6 years ago
    Has this issue been resolved?  If so could some one post an answer.
  • excellon1
    excellon1 over 6 years ago in reply to Wild
    The 3D Viewer is working in S052. Maybe someone can chime in on S051
  • Wild
    Wild over 6 years ago in reply to excellon1
    Sorry Community, I resolved this issue and did not post the solution.
    I use Flowtherm and integrating the export function from Allegro to Flowtherm changes the menu structure.  With out changing the menu code myself  I am able to invoke the 3D by executing the command at the command line.
    BTW I wish I could execute the team members at Cadence that added the startup window to Allegro Disappointed
  • RFinley
    RFinley over 6 years ago in reply to Wild
    >Setup >User Preferences Editor, >UI, >StartPage to disable it in 17.2
  • Wild
    Wild over 6 years ago in reply to RFinley
    TY Slight smile
    Don't need to execute the developers any,ore, just make them feel some pain.. Slight smile
