  3. Simulation Issue
  • Views 14725
Simulation Issue
Silverwolfman
Silverwolfman over 6 years ago
Hi It is my first time using Pspice simulation and I encountered some issues.
Could anyone help me to take a look if there is anything I didn't config correctly in the spice model?
Thx.
** Creating circuit file "Test.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
.LIB "../../../lib/lmh6553.lib"
* From [PSPICE NETLIST] section of C:\SPB_DATA\cdssetup\OrCAD_PSpice\17.2.0\PSpice.ini file:
.lib "nom.lib"
*Analysis directives:
.TRAN 0 100ns 0
.OPTIONS ADVCONV
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source SIMULATION
V_V4 N13378 0 6Vdc
R_R65 N13358 A1_INP 499 TC=0,0
R_R71 N13436 N13378 4.99k TC=0,0
R_R68 A_OUTN N13358 536 TC=0,0
R_R63 0 A1_INP 56.2 TC=0,0
V_V5 N13858 0 1.9Vdc
V_V2 A1_INP 0 DC 1.9Vdc AC 0.25Vac
R_R66 N13962 A1_INN 499 TC=0,0
C_C278 0 N13762 10.1u TC=0,0
R_R64 A1_INN 0 56.2 TC=0,0
C_C281 ADC1_AIN_N ADC1_AIN_P 5p TC=0,0
C_C275 0 A1_INP 1p TC=0,0
V_V6 A1_INN 0 DC 1.9Vdc AC 0.25Vac
R_R67 A_OUTP N13962 536 TC=0,0
R_R72 0 N13436 4.42k TC=0,0
R_R69 ADC1_AIN_P A_OUTP 49.9 TC=0,0
C_C280 N13378 N13762 0.1u TC=0,0
C_C277 N13858 0 0.01u TC=0,0
C_C279 0 N13378 10.1u TC=0,0
R_R70 ADC1_AIN_N A_OUTN 49.9 TC=0,0
V_V3 N13762 0 -6Vdc
C_C276 A1_INN 0 1p TC=0,0
X_U1 N13378 N13762 N13358 N13962 A_OUTN A_OUTP N13858 N13436 LMH6553
**** RESUMING Test.cir ****
.END
X_U1.q9 X_U1.a140 N13858 X_U1.a149 0 X_U1.NPNXTR
X_U1.q1 X_U1.a176 X_U1.a134 X_U1.a252 0 X_U1.NPNXTR
X_U1.q10 X_U1.a146 X_U1.a148 X_U1.a174 0 X_U1.NPNXTR
X_U1.q11 X_U1.a149 X_U1.a134 X_U1.a222 0 X_U1.NPNXTR
X_U1.q3 X_U1.a119 X_U1.a111 X_U1.a154 0 X_U1.PNPXTR
X_U1.q5 X_U1.a111 X_U1.a111 X_U1.a157 0 X_U1.PNPXTR
X_U1.q4 X_U1.a199 X_U1.a111 X_U1.a160 0 X_U1.PNPXTR
X_U1.v2 X_U1.a241 X_U1.a174 0
X_U1.v1 X_U1.a202 X_U1.a176 0
X_U1.i9 X_U1.a0100 X_U1.a0198 2.5e-6
X_U1.i5 N13378 X_U1.a148 12e-6
X_U1.i0 N13378 X_U1.a108 7e-3
X_U1.f2 0 X_U1.a203 X_U1.v2 1.0
X_U1.f3 0 X_U1.a205 X_U1.v2 1.0
X_U1.f1 0 X_U1.a205 X_U1.v1 -2.0
X_U1.f0 0 X_U1.a203 X_U1.v1 2.0
X_U1.rtm 0 X_U1.a205 128e3
X_U1.r29 X_U1.a222 N13762 250
X_U1.r30 X_U1.a224 N13762 250
X_U1.r31 N13378 X_U1.a113 250
X_U1.rtp X_U1.a203 0 128e3
X_U1.r32 N13378 X_U1.a115 250
X_U1.r20 N13378 X_U1.a157 250
X_U1.r15 X_U1.a0113 X_U1.a148 2.5e3
X_U1.r22 N13378 X_U1.a160 175
X_U1.r16 X_U1.a148 X_U1.a0117 2.5e3
X_U1.r33 X_U1.a149 X_U1.a241 200
X_U1.rtc X_U1.a108 N13762 14.3 tc1
ERROR(ORPSIM-16015): Unknown parameter.
  • Alok Tripathi
    Alok Tripathi over 6 years ago
    LMH6553 model is not compatible for PSpice. I assume you are using model downloaded from TI.com.  Following line in model
    rtc a108 vee 14.3 tc1=400e-6 tc2=-5e-6
    is troubling PSpice.
    This syntax is not supported by PSpice. simplest fix would be modify this line model as following
    rtc a108 vee 14.3 ;tc1=400e-6 tc2=-5e-6
    this will exclude two temperature coefficient from model.
    If you wish to include these modify the above line as following
    rtc a108 vee 14.3 tc=400e-6, -5e-6
  • Silverwolfman
    Silverwolfman over 6 years ago in reply to Alok Tripathi
    Hi alokt,
    Thank you so much for the help, it works now!
