  3. DRC ERROR
  • Views 13201
DRC ERROR
Filo88
Filo88 over 6 years ago
Hi everybody,
I'm writing because I would like ask to you a suggestion about DRC.
For examle: I have a net ( It is a shunt) with an min line width of 1 mm. I need to read the current so I have to take the signal an to go to comparator. The part of net that go to comparator is 0,2 mm ( it hasn't to be1 m) and correctly i have DRC error.
Do you know a way for not have this error only part of small net? Do you have any suggestions?
Thanks.
  • steve
    steve over 6 years ago
    You can either Waive the DRC or draw a Constraint Region around that part of the cline and set the rule for the cline inside the area.
