  3. how can i use *.ebd file in my front simulation?
  • Subscribers 163
  • Views 14055
archive over 18 years ago
Buddy:
         how can i use *.ebd file in my front simulation with Sigxp?
         Someone told me to read the *.ebd file, and create the topology and model from the *.ebd content.But i cann't know all the syntax from the SQ help.
        Is there any other way to use the *.ebd file .
        thks
        expect ur reply!
Originally posted in cdnusers.org by uptonzhou
    By the way,how can set TL line when know the TL line parmeter(R.l,C)?
    EBD files are a standard part of IBIS translation. Make sure all the files it calls are present, and then do Translate -> ibis2signoise and point to the .ebd file. It will convert the syntax to a DML file. If the .ebd file represents a component instead of a PCB, then use the -ebdcomp switch with the translator. Also, somewhere there's a perl script to convert the format into Espice black box models for SigXp should you desire to do that.
    Hope that helps,
    Donald
    Originally posted in cdnusers.org by Donald Telian
    thks u help!
    br!! buddy!!
