  3. how to fix issue when importing DXF
  • Subscribers 166
  • Views 18213
hgvghvgh
hgvghvgh over 6 years ago
my question is how to fix the issue when importing DXF using cadence 17.2 . the DXF is ok for cadence 16.5.   the issue is logged as following:
Reading Layer Conversion File
Reading DXF file...
ERROR: 3D data has been found in this dxf file.
  Most 3D data is not supported by dxf2a.
  For the special case of DXF code 230 = -1.0, ARC, CIRCLE
  and SOLID entities will be mirrored about the Y axis.
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 4842
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 4876
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 5118
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 8102
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 8136
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 8378
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 9060
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 9094
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 9336
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 10440
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 10474
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 10716
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 14708
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 14746
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 14784
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 14822
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 14860
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 14898
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 14936
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 14974
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 15012
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 15050
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 15088
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 15126
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 15164
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 15202
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 15240
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 15278
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 15316
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 15354
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 15392
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 44200
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 44234
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 44264
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 44304
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 44334
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 44374
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 44404
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 44444
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 44474
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 44514
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 44544
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 44584
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 44614
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 44654
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 44684
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 44724
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 44754
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 44794
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 44824
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 44854
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 44884
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 44914
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 44944
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 44974
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 45004
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 45034
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 45068
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 45102
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 45132
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 45172
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 45206
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 45236
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 45276
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 45570
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 45604
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 45846
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 47086
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 47120
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 47362
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 47400
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 47438
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 47476
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 47514
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 56846
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 56880
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 56914
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 56948
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 56982
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57016
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57050
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57084
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57118
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57152
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57186
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57220
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57254
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57288
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57322
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57356
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57390
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57424
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57458
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57492
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57526
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57560
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57594
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57628
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57662
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57696
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57730
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57764
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57798
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57832
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57866
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57900
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57934
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 57968
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 58002
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 58036
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 60514
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 60548
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 60790
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 62026
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 62060
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 62302
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 62340
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 62378
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 62416
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 62454
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 62492
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 62530
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 62568
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 62606
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 73492
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 73522
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 73562
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 73592
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 73632
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 73662
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 73702
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 73732
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 73772
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 73802
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 73842
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 73872
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 73912
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 73942
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 73982
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 74012
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 74052
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 74082
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 74112
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 74142
ERROR: 3D data (DXF code 230, value = 1.0000) detected on CIRCLE at line 74172
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 74206
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 74240
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 74274
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 74308
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 74342
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 74372
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 74412
ERROR: 3D data (DXF code 230, value = 1.0000) detected on LINE at line 74446
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 74476
done.
NOTE: Ignoring unsupported element VIEWPORT on line 1882.
Layer conversion file: C:/Quentin/2019/UP725/725 new DXF PCB small size 20190520/123350950-01_20190520_l.cnv
DXF file: C:/Quentin/2019/UP725/725 new DXF PCB small size 20190520/123350950-01_20190520.dxf
BRD file: C:/Quentin/2019/UP725/725 new DXF PCB small size 20190520/PCB/#Taaaacu12768.tmp
Update existing design?: NO
Use default text?: NO
DXF units: MILLIMETERS
Design units: MILLIMETERS
Design precision: 4
dxf2a complete.
  • Sagetech
    Sagetech over 6 years ago
    What program are you using to generate the DXF?
  • hgvghvgh
    hgvghvgh over 6 years ago in reply to Sagetech
    Catia
  • UlfK
    UlfK over 6 years ago
    You have two options:
    1. Go to the mech guy and sit next to him and make him open his newly created DXF that contains the 3D data
    and make him remove the 3D "layers" or "elevations". Then make sure that the contour is "healed" so that there are no
    open ends and that the contour is a closed polyline.
    2. Install AutoCAD or Get a free DXF-editor (there are some that can be found on the net) and open the .DXF, then if the software
    can rotate the 3D .DXF, do this and manually remove all "vertical" segments and underlaying elements.
    It may also be necessary to check for multiple lines in same coordinates.
    If using AutoCAD: Do PURGE unused blocks and when using PEDIT, it is possible to heal broken geometries.
    Also, edit the .DXF and limit the size of the .DXF so that the data extent is only the geometry itself (Drawing|Limits)
  • hgvghvgh
    hgvghvgh over 6 years ago in reply to UlfK
    thank you very much. option 1 fixed the problem. there are many open ends there. after delete the non-usable line  it's ok.
