  3. Block Designing
  • Views 13586
Block Designing
TIDVEng
TIDVEng over 6 years ago
My goal for my current project is to create a Hierarchical Block Library in Cadence for my team and I to use in the future. With that said, here are my questions:
1) After I have created my hierarchical blocks, how can I export them as a library for my coworkers to import and use in the easiest way possible?
2) I would like to use hierarchical blocks inside of hierarchical blocks, is it possible? How does the naming of the larger block propagate to that of the block inside of it? Could you provide instructions on how to use the blocks inside of a block?
3) Can we have different versions of a block? My goal is to have a single block with multiple versions of the same said component that would have different configurations.
4) In the component library that I have created, I have extra components in the Component View that I do not want. How can I delete them? (control + delete does not work)
Thank you for the help, it is very much appreciated.
  • Wild
    Wild over 6 years ago
    Hierarchical Design Example for Design Reuse Part1.pdfMaybe this may help.
    I wrote this several years ago.
    I have used resuse models alot in the past for designs such as high count telephony line feeds where a board could have dozens of the same circuit.  I hope this helps.
    Note I had to break up the document into 2 parts due to Cadence up load size restrictions
    Continue to my next post.
    Wild
  • Wild
    Hierarchical Design Example for Design Reuse P2.pdf
    Part 2
  • Wild
    1. I have created HhBlocks as a library item many years ago, it can be done, including the MDD file.
    2. Not sure about the naming, I believe there is a way with atcl tool, but it can be done manually very easy.
    3. A block as a variant is what i believe you are asking, - outside of my experience sorry.
    4. Not sure maybe a refesh cache?
    Wild
