  3. Trimming off one corner of a package outline (Assembly_Top...
  • Views 6876
Trimming off one corner of a package outline (Assembly_Top and silkscreen) to indicate pin one.
FormerMember
FormerMember over 6 years ago
Attempted Actions (OrCAD 17.2, hotfix 55):
RMB->Application Mode->Shape Edit
Option Menu
      Active class and subclass 'Package Geometry'/Assembly_Top
     Vertex Command->Click: select 'Chamfer/Round'
     Corners: tick Chamfer radio button
     Trim(T) set to 10mil
Left click on silkscreen rectangle vertex near pin 1 (6-pin SOT Filled or unfilled, not Fixed):
Problem:There isn't a 'Trim Vertex' option. The only Shape Edit mode menu option is 'Trim Corners', which trims multiple corners.
The part can be freely edited in General Edit Mode
Thanks in advance.
-Keith
Thanks in advance for your help.
  • steve
    steve over 6 years ago
    Shape Edit Mode is only valid for Shapes so try General Edit mode and RMB> Edit Vertex or just use the Menu Edit - Vertex. If it is a shape the Trim corners does work on all corners but you can hover over a single corner and left click and only that corner is chamfered.
