  3. When the schematic diagram is opened in 17.2 HF055 capture...
  • Views 13728
When the schematic diagram is opened in 17.2 HF055 capture, probability cannot be selected by clicking
Kinzhifeng
Kinzhifeng over 6 years ago
After opening the schematic diagram in the capture, the probability can only click on the selected electrical node, not anything, but the area selection is no problem.
  • steve
    steve over 6 years ago
    Check the selection Filter is all enabled (right click in blank space and choose Selection Filter).
    • Vote Up -1 Vote Down
  • Kinzhifeng
    Kinzhifeng over 6 years ago in reply to steve
    I tried it. Select Filter only works for area selection, but it doesn't work for click selection. Even if Select Filter disables all elements, it can also click to select all elements.            The problem I encountered didn't seem to be caused by select filter.
