  3. Far/ near field graphic viewer
  • Subscribers 163
  • Views 13971
archive over 18 years ago
Hi
I want to get any program to view near field result from PCB SI EMI-Single simulation.
I used this kind of program long time ago.
PCB SI EMI-Single is very powerful and useful to find optimal design solution by trade-off management , even if the accuracy is another topic with 3D EM solution : Ansoft, CST, etc.
Could you please show me how to get the solution or program?
Originally posted in cdnusers.org by bkpark
    archive over 17 years ago
    Hi bkpark
    I performed near field simultation and me too I am looking for a viewer for XY datas.
    I logged an Service Request, but the result was negative. Only an advice to find a 3rd party program.
    Do you found a program?
    It's damage to have the datas and not be able to use them.
    Patrick.
    Originally posted in cdnusers.org by desaphix
    Hi Patrick
    I don't find proper program for this. but I found Matlab or other static analysis program like minitab can be used to display for XY datas.
    I think that we can use the sigwave result of near field to find the max and critical frequency, maybe that is enough.
    But I will keep to find the way to display the each frequency and XY datas and compare this with Full 3D tools.
    I will let you know when I find good method.
    BK Park
    I remembered the name of Cadence FAE who provided the program to display XY Datas when I worked with Cadence.
    This program is not free of charge but I think this is very powerful and easy to use.
    Kevin Chung kevinqc@cadence.com
    If Kevin is working with Cadence, I will contact with him
    BK Park
    Hi BK Park
    Thanks for the answers.
    I found a freeware to view XYZ datas, its name is QUIKGRID
    You can import directly each file and view the magnitude of the H/E near field for each frequency in colour. It’s a powerful program, you have many view options.
    You can download it at http://www.perspectiveedge.com/
    Patrick
