  3. How to create a report for PACKAGE_HEIGHT_MAX
  • Views 14327
Lock2002
Lock2002 over 6 years ago
I'm trying to create a custom report that will generate max component heights, ref designators and whether they are mirrored or not. It will report the designators and mirror status, but not the package height.
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    Does the report shown below solve your issue?
    D:\SPB_Data\intel\ionize>cat test.txt
    COMPONENT
    REFDES_SORT
    REFDES
    COMP_HEIGHT
    SYM_MIRROR
    D:\SPB_Data\intel\ionize>grep test allegro.jrl | tail -1
    \i (00:07:39) reports "./test.txt" nographic write test.dat
    D:\SPB_Data\intel\ionize>head test.dat
    Allegro Report
    D:/SPB_Data/intel/ionize/Ionize_HP_Mezz_ElliottKey_0809.brd
    Tue Sep 03 08:38:09 2019
    REFDES,COMP_HEIGHT,SYM_MIRROR
    C1,.024 IN,YES
    C6,.024 IN,YES
    C7,.034 IN,YES
    C10,.057 IN,YES
    C11,.057 IN,YES
  • Lock2002
    Lock2002 over 6 years ago in reply to DavidJHutchins
    unfortunately, no. Our package heights are defined by a property attached to the place boundary (PACKAGE_HEIGHT_MAX).
  • DavidJHutchins
    Then try this one...
    D:\SPB_Data\intel\ionize>type test2.txt
    GEOMETRY
    CLASS = PACKAGE GEOMETRY
    SUBCLASS = 'PLACE_BOUND_TOP'
    SYM_TYPE = PACKAGE
    OR
    SUBCLASS = 'PLACE_BOUND_BOTTOM'
    SYM_TYPE = PACKAGE
    REFDES
    SYM_MIRROR
    PACKAGE_HEIGHT_MAX
    END
    D:\SPB_Data\intel\ionize>grep test2 allegro.jrl
    \i (00:00:21) reports "./test2.txt" nographic write test2.dat
    D:\SPB_Data\intel\ionize>head test2.dat
    Allegro Report
    Tue Sep 03 09:42:56 2019
    REFDES,SYM_MIRROR,PACKAGE_HEIGHT_MAX
    EU2100,NO,58 MIL
    EU2100,NO,58 MIL
    EU2100,NO,58 MIL
    EU2100,NO,58 MIL
    F1,NO,18 MIL
  • Lock2002
    Almost there. Can you do this without duplicates? I'm getting between 4 and 8 duplicates per designator. Thanks for your help!
  • DavidJHutchins
    I can't see any options in the extracta command file format to remove the duplicate entries ( I'm guessing it's reporting for every vertex in the place_bound shapes )
    I think the simplest solution would be to use the unix/linux 'uniq' command to remove the duplicate entries:
    D:\SPB_Data\intel\ionize>wc test2.dat
    2245 4486 37453 test2.dat
    D:\SPB_Data\intel\ionize>uniq test2.dat > test2a.dat
    D:\SPB_Data\intel\ionize>wc test2a.dat
    619 1235 10368 test2a.dat
    D:\SPB_Data\intel\ionize>head test2a.dat
    Allegro Report
    EU2100,NO,58 MIL
    F1,NO,18 MIL
    F2,NO,18 MIL
    FB20,NO,55 MIL
    FB11,NO,55 MIL
