  3. After updating the OrCAD CIP Server to v17.2.13.4 the server...
  • Views 13825
After updating the OrCAD CIP Server to v17.2.13.4 the server no longer starts.
KeithWSS
KeithWSS over 6 years ago
My channel partner, EMA Design Automation, recommended I update my CIP Server and Client to the latest version. After the update, CIP Server won't start.
This is the information the CIP tab displays in Capture CIS:
ERROR [08001] [Microsoft][ODBC SQL Server Driver][DBNETLIB]SQL Server does not exist or access denied.
ERROR [01000] [Microsoft][ODBC SQL Server Driver][DBNETLIB]ConnectionOpen (Connect()).
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.Odbc.OdbcException: ERROR [08001] [Microsoft][ODBC SQL Server Driver][DBNETLIB]SQL Server does not exist or access denied.
Source Error:
Line 31:
Line 32: function openAbout(event) {
Line 33: var aboutConfig = { title: '@Html.Raw(CIPProperties.ProductTitle)', serverVersion: '@CIPProperties.Version', databaseVersion: '@Global.Configuration.DatabaseVersion' };
Line 34: event.preventDefault();
Line 35: ema.cip.showAboutDialog(aboutConfig);
Source File: c:\Cadence\CIP-E\CIP\Views\Shared\_Layout.cshtml Line: 33
Stack Trace:
[OdbcException (0x80131937): ERROR [08001] [Microsoft][ODBC SQL Server Driver][DBNETLIB]SQL Server does not exist or access denied.
ERROR [01000] [Microsoft][ODBC SQL Server Driver][DBNETLIB]ConnectionOpen (Connect()).]
EMA.CIP.CIPODBCDatabaseAdapter.ExecuteReader(OdbcCommand cmd) +168
EMA.CIP.CIPODBCDatabaseAdapter.SelectFromTable(String tableID, List`1 selectFieldIDs, List`1 whereFieldIDs, List`1 parameters, Boolean distinct) +1309
EMA.CIP.CIPODBCDatabaseAdapter.GetProperty(String property, String defaultValue) +232
EMA.CIP.CIPConfiguration.LoadFromDatabase(String[] roles, ICIPDatabase databaseAdapter) +272
EMA.CIP.Global.get_Configuration() +808
ASP._Page_Views_Shared__Layout_cshtml.Execute() in c:\Cadence\CIP-E\CIP\Views\Shared\_Layout.cshtml:33
System.Web.WebPages.WebPageBase.ExecutePageHierarchy() +252
System.Web.Mvc.WebViewPage.ExecutePageHierarchy() +148
System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) +122
System.Web.WebPages.<>c__DisplayClass40_0.<RenderPageCore>b__0(TextWriter writer) +309
System.Web.WebPages.WebPageBase.Write(HelperResult result) +108
System.Web.WebPages.WebPageBase.RenderSurrounding(String partialViewName, Action`1 body) +89
System.Web.WebPages.WebPageBase.PopContext() +310
System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context) +375
System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +88
System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +775
System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult) +81
System.Web.Mvc.Async.<>c__DisplayClass3_1.<BeginInvokeAction>b__5(IAsyncResult asyncResult) +188
System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult) +38
System.Web.Mvc.<>c.<BeginExecuteCore>b__152_1(IAsyncResult asyncResult, ExecuteCoreState innerState) +26
System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +68
System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult) +52
System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +39
System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult) +38
System.Web.Mvc.<>c.<BeginProcessRequest>b__20_1(IAsyncResult asyncResult, ProcessRequestState innerState) +40
System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +38
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +602
System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) +195
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +128
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.7.3429.0
