  3. silkscreen not associated with a pcb symbol
  • Views 14345
Telesis86
Telesis86 over 6 years ago
What's the best way to search for all elements (lines, shapes, text, etc) in package geometry/silkscreen class/subclass that were added in the board level?
  • Dale Peterson
    Dale Peterson over 6 years ago
    Hi, well the best way to identify graphics not associated with components-- Temporarily unplace your components. What's remaining on the silkscreen layer will be what's not associated with the components.
  • Telesis86
    Thank you. That will work.
    If one of these talented members can create a skill code to search for these unassociated elements and create DRC's that would be a bonus
  • DavidJHutchins
    DavidJHutchins over 6 years ago in reply to Telesis86
    the code below will create external drc flags on "package geometry" items that do not have a parent object/symbol owner:
    procedure((Find_Orphans)
    let((errcnt llx lly urx ury center_x center_y layer dbid)
    (errcnt = 0)
    ;; process top side
    (axlClearSelSet)
    (axlVisibleDesign nil)
    (axlVisibleLayer "PACKAGE GEOMETRY" t)
    (axlSetFindFilter ?enabled (list "noall" "lines" "shapes" "text") ?onButtons (list "lines" "shapes" "text"))
    (axlAddSelectAll)
    foreach(obj axlGetSelSet()
    unless((obj->parent)
    (llx = caar(obj->bBox))
    (urx = caadr(obj->bBox))
    (ury = cadadr(obj->bBox))
    (lly = cadar(obj->bBox))
    (center_x = (((urx - llx) / 2) + llx))
    (center_y = (((ury - lly) / 2) + lly))
    if(nindex(upperCase(obj->layer) "_TOP") then
    (layer = "Drc Error Class/Package_Top")
    else
    (layer = "Drc Error Class/Package_Bottom")
    (dbid = axlDBCreateExternalDRC("Orphan Object" (center_x:center_y) layer list(obj) nil nil))
    when(dbid
    (axlHighlightObject car(dbid) nil)
    (errcnt++)
    ;; done
    axlMsgPut("%d DRC flags added" errcnt)
    axlCmdRegister( "find_orphans" 'Find_Orphans ?cmdType "general")
  • Telesis86
    Telesis86 over 6 years ago in reply to DavidJHutchins
    David - Thank you. I will give it a try as soon as I can.
  • avant
    avant over 5 years ago
    Highlight all symbols (use * as the find filter) using the dark gray or black color.
    Everything not highlighted is not part of a symbol.
