  3. Extracting Multiple Nets from PCB Editor into SigXplore...
  • Replies 8
  • Subscribers 163
  • Views 16967
Extracting Multiple Nets from PCB Editor into SigXplorer
archive over 17 years ago
I hope that this question is appropriate for this forum
I am using the "L" version of PCB Performance and SigXplorer and am still somewhat new to them.
I am trying to use the Topology Extract feature to extract a net into SigXplorer. The net is actually divided into 2 individual nets with 2 net names. Net #1 is routed from the driving source to one side of a series terminating resistor. Net #2 connects the other side of the term. resistor to the receiver.
Using Topology Extract, I can only seem to extract one net or the other (including the resistor) into SigXplorer. How do I specify that I want to extract the entire net (from source to receiver)?
Thank You
Nick
Originally posted in cdnusers.org by nipri
    You can change a device type in Logic - Parts List but if you have correctly assigned an espice model to the rpack, this should not be a problem.
    Originally posted in cdnusers.org by Kalevi2
    Extracting through the resistor should work (eventually!). Make sure you have PinConnections.
    When all else fails, you can extract the two nets separately and then use the File -> Append feature to glue them together. That feature is powerful yet simple, and works quite well.
    Donald
    Originally posted in cdnusers.org by Donald Telian
    I've seen cases in the L version of the tools where you need to run Tools, Database check inside the PCB Editor in order for it to recognize the xnet after assigning espice models to resistors - so try that.
    Best regards,
    Ole
    Originally posted in cdnusers.org by ejlersen
