  3. Altium to OrCAD 17.2 Translation Issues
  • Replies 10
  • Subscribers 166
  • Views 19850
EASiA
EASiA over 5 years ago
Hello all,
I have an issue for which I cannot find a solution.
I have translated an Altium schematic using File->Import->Altium Schematic Translator. Under the dialog box, there is a help file that explains what needs to be done in both Altium and OrCAD. I saved the files as the Advanced Schematic ascii (*.SchDoc) as directed. There is a PCB Project file (*.PrjPCB) and a valid structure file (*.PrjPCBStructure). I converted all of the Altium schematic pages to custom so the page sizes will be correct. Almost everything translated properly except the few things that is indicated that it cannot understand such as the signal harness where the signals are combined into one fancy line. That is not an issue for me at the moment. The main issue I have is the non-aliased nets reverted to an OrCAD default naming style, something like N00027 from say Q6_1. This is not necessarily a problem either. I know that OrCAD capture cannot change the names of the nets back to the Altium style.
The problem that I know I will have is when I try to link the PCB to the schematic. I know that I will have to re-run the Tools->Create Netlist... to recreate the netlists. This will be the problem. When I translated the Altium PCB to OrCAD, I followed the same instructions that were found Import->Translators->Altium PCB.... The help file under that dialog box explains that you need to save the PCBs as a PCB ASCII File (*.PcbDoc). I checked the Create Individual Symbol Definitions and Derive Connectivity check boxes as well as the Extended radio button. The board was completely translated. All of the traces/nets were translated as they are on the Altium PCB.
The issue that I have is the translated PCB nets do not match because none of the non-aliased nets changed into a default net like in the schematic. So the question is, how do I change the PCB to make the traces/nets conform to the schematic net naming so I can recreate the netlists?
Any help would be greatly appreciated.
  • EASiA
    EASiA over 5 years ago in reply to CadAce2K
    I succeeded in connecting the schematic to PCB. You were right when you said that the nets would automatically change. However, I have two issues that I can see at the moment. One, inexplicably, some of the nets changed to GND. There is not GND connected to these pins. Both pins that are connected show the net name but the trace turned to GND. The other thing, some of the parts rotated for no apparent reason. Those can probably just be rotated but there are a lot to rotate. It also seemed to only affect the resistor types (for the rotation). Any ideas on how to fix these issues?
  • CadAce2K
    CadAce2K over 5 years ago in reply to EASiA
    1) Traces connected now to GND. Yep, that happens a lot. My method is to simply delete the via at the segment coming off the pin. Then Add/Connect and add a via back onto the net. It should re-connect the net correctly. Sorry, but that happens a lot (I've done countless translations from PADS to Allegro and it always happens). Tedious to have to do, but still easier than starting a new design file and re-create everything (right?).
    2) Components coming in backwards. That's a footprint issue, with regards to your library. Your library parts are created backwards from the Altium or PADS schematic. Simple Edit/Spin ; set the rotation to 'absolute' and the required rotation (to spin them 180 degrees) and start pick the symbols to rotate. Easy-peasy. Even a large amount of comps can be spun in 5 minutes or so.
    Good day.
  • EASiA
    I discovered the reason that the netlist did not carry over correctly. It was because I was working with Hierarchical design and using NetGroups. The Altium design used net harnesses which is just a conduit for a group of nets. NetGroups are practically the same thing. Therefore, I made all of the areas that had the Altium net harnesses and turned them into NetGroups. The thing I did not know was I had to use NetGroups (w/o the box) to link the hierarchical boxes together (H pin with a Netroup Bus). I was just using a bus line. So in essence, there was no connection between them and I guess OrCAD defaulted to a GND signal.
    I will try the thing you mentioned about the components.
  • EASiA
    EASiA over 5 years ago in reply to EASiA
    I tried to do exactly what you said,
    When I ran Create Netlist again, the components stayed flipped. The weird thing is, it only happened to the R0603 symbol. Only those flipped. I do not know why. I saw on another post from oldmouldy (https://community.cadence.com/cadence_technology_forums/f/pcb-design/24907/netlist-import-removes-placed-components) that maybe it is a logic issue but I would not know how to even analyze it. Anybody have any suggestions?
  • CadAce2K
    Really nothing to analyze. It's just an issue between the PCB footprint in your library vs. the schematic symbol. You either need to 'mirror' the symbols in your schematic so it comes across fine in your layout; or 'spin' the footprints in the layout so they'll map fine to your schematic netlist. It's simply an issue you'll deal with as you do more translations. No biggie. As I've said, just tedious.
    Good day.
