  3. Report of Dynamic Shape Instance Parameters
  • Replies 8
  • Subscribers 166
  • Views 17015
Geras
Geras over 6 years ago
I have a board with hundreds of dynamic shapes where some of the shapes have instance parameters set that differ from the global parameter.  How can i get a report of every dynamic shape and what it's dynamic shape parameters are?  Or any other method that will tell me what shapes don't follow the global rules?
  • Geras
    Geras over 6 years ago in reply to eDave
    Thanks so much!  This does exactly what I was hoping.  My only question now is how do i correlate the shapes in this printout with the the shapes on the board?  Every shape has a priority number however that doesn't seem to line up with the priority numbers printed out if i query by by shape priority in the selection tool.  (all of those priorities have a negative number)
  • eDave
    eDave over 6 years ago in reply to Geras
    The line of code I sent you will just give you the layer and the bounding box of the shape. Here's a very basic function that might help some more:
    defun( DE_reportDynamicShapes ()
    let((shps, shpsList, n, hilightedShape, layer)
    shps = setof(shp, axlDBGetShapes("BOUNDARY"), length(axlDBGetProperties(shp ->dynamicGroup)) > 1)
    shpsList = mapcar(lambda((shp), lsprintf("%s: %L\n", shp ->layer, axlDBGetProperties(shp ->dynamicGroup))), shps)
    while((n = axlUIMultipleChoice("Select a shape", shpsList)) && n >= 0
    when(hilightedShape, axlDehighlightObject(hilightedShape))
    hilightedShape = nth(n, shps)
    layer = hilightedShape ->layer
    unless(axlIsVisibleLayer(layer), axlVisibleLayer(layer, t))
    axlHighlightObject(hilightedShape)
    axlZoomToDbid(hilightedShape, t)
    axlUIConfirm(lsprintf("%L", axlDBGetProperties(hilightedShape ->dynamicGroup)))
    axlVisibleUpdate(t)
  • Geras
    Thanks!  That is really great, however it was still hard to see which shapes had which parameters and difficult to go through them all since the list reset after checking every shape.  I was able to to use axlDbidName(s ->net) in place of s ->dBox to give me the net name and now that list is great!  Thanks so much.  It's still really surprising to me that Allegro doesn't have a built in way to check all items that don't follow a global rule.  It makes it really hard to do an audit of a design.
