  3. SigNoise Errors/Warnings - Field Solution failed for STL_1S_1R_1016...
  • Views 1113
ZETA1234
ZETA1234 over 5 years ago
I am a new user of OrCAD PCB Designer Pro. I setup my differential/single-ended impedance in the Electrical Constraints and all of my widths and spacing in the Physical Constraints but now when I try to route I get flooded with these errors. I am not sure how to resolve it or turn off the calculation. Please help.
ERRORS:
Field solution failed for STL_1S_1R_1184
Field solution failed for STL_1S_1R_1183
Field solution failed for STL_1S_1R_1182
Field solution failed for STL_1S_1R_1181
Field solution failed for STL_1S_1R_1180
Field solution failed for STL_1S_1R_1179
