  3. Regional constraint set at Allegro 16.6
  • Views 13791
KobiC
KobiC over 5 years ago
Hi All,
I'm using Allegro PCB editor 16.6.
In my layout, I'm trying to create a regional constraint.
After I set the constraint region and the layer and assigned a region name - I marked the region on the layer with a rectangle shape and then open constraint manager window.
However, in "physical" tab, the "Region" section is not shown, thus can't set a regional rule set.
Am I missing something?
  • steve
    steve over 5 years ago
    Check your exact version of software from Help - About. Make sure you are running the latest release of 16.6 S115. If you are not running this then get the latest version from support.cadence.com. Also make sure you have a license from Allegro PCB Designer or OrCAD Professional. OrCAD Standard does not have this capability.
