  3. A GenCAM from Allegro
  • Replies 33
  • Subscribers 168
  • Views 26624
archive over 20 years ago
Hi cadence
I want to know that is it possible to generate GenCAM file from cadence allegro 15.2?
Please let me know ASAP.
Waiting for reply.........
Originally posted in cdnusers.org by naren_thesia
    archive over 18 years ago
    Hi Nso,
    This isn't an Orcad Editor version. This only works with Allegro. You'll need to read the readme doc file inside the .zip file.
    Good day.
    Mitch
    Originally posted in cdnusers.org by cadpro2k
    FROM THE CADENCE ALLEGRO.doc file:
    Cadence Allegro running on Windows NT
    1. In order to extract ASCII cad files from Cadence Allegro running on Windows NT, CircuitCAM provides two versions of batch and command files. These files must be used with Allegro’s EXPORT utility.
    • XTRCT.BAT (XTRCT.CMD): These files make up the standard script which produces ASCII cad files without the net list information. This is the preferred script because the resulting ASCII files will be much smaller than those produced with the XTRCTNET.BAT script.
    • XTRCTNET.BAT (XTRCTNET.CMD): These files make up the script which produces ASCII cad files with the net list information. This script will produce a much larger ASCII file than those from the XTRCT.BAT script. Consequently, the corresponding CircuitCAM project file will also be much larger. If net list information is required, then this script must be used.
    2. Before running a script, place the batch and command files in the current working directory of the Allegro database.
    3. To activate the script file, type XTRCT.BAT (or XTRCTNET.BAT) followed by the board design file name at the DOS prompt. The script file will use the corresponding command file and produce an ASCII cad file. The generated file will be CCAM.CAD (XTRCT.BAT) or CCAMNET.CAD (XTRCTNET.BAT).
    4. The generated file should then be renamed to represent the board design file from which it was created.
    Hi cadpro,
    But, do you know a solution to transform a .brd of Orcad PCB DESIGNER in .cad like with Orcad Layout with the command export GENCAD??
    Good day.
    Nico
    Originally posted in cdnusers.org by nsochala
    Sorry Nico, I don't know.
    You might check the EMA-EDA.com website (product support) to see if there is such a thing.
    Good day.
    Mitch
    I would like to have these script files also ,if you can make it available to me. My email is satya_pcbdesign@rediffmail.com
    Originally posted in cdnusers.org by satya1234
