  3. A GenCAM from Allegro
  • Replies 33
  • Subscribers 168
  • Views 26666
archive over 20 years ago
Hi cadence
I want to know that is it possible to generate GenCAM file from cadence allegro 15.2?
Please let me know ASAP.
Waiting for reply.........
Originally posted in cdnusers.org by naren_thesia
  • EA PCB Design
    EA PCB Design over 16 years ago
    Could somebody send the script to me too??
    jack.ummels@ea-pcb.com
    tnx
  • Brian
    Brian over 16 years ago
    Here it is.
    Cad_export_Scripts.zip
  • windows 7
    windows 7 over 11 years ago
     Hi
    I Am not able to generate the GenCam file from this script and in skill also it is showing some errors please let me know how to generate the GenCam file from Allegro.
    Regards
    Vimal
  • Ejlersen
    Ejlersen over 11 years ago
    Hi
    If you're looking for a CircuitCAM file with the extension .cad then I've embedded the code into a skill file that is attached.
    You need to load it from your allegro.ilinit files with the following commands.
     load("ns_aegis.il" "nsWare") - the last bit is important since it is password encrypted today.
    If you need the source code let me know and I'll try to change it for a format that is easier to read
    Best regards
    Ole
    ns_aegis.zip
  • emldebh61
    emldebh61 over 6 years ago in reply to Ejlersen
    HI Ole
    Hopefully you are still around :-) Long time no speak. Do you have the source code for this ?
    Dave
