  3. warning: "could not fit symbol"
  • Views 2841
archive over 20 years ago
I get this message on a couple of symbols now when trying to quickplace. Any clues??
thanks
Originally posted in cdnusers.org by Roseann
    It sounds like your drawing size is too small to fit the symbols in. Select Setup > Drawing Size and increase the size or select Place > Manually and see if you can place the symbols inside the outline. Let us know if this helps. Thanks!
    Originally posted in cdnusers.org by Padmin
    another possibility may be that your symbol is built with a piece of geometry far away from the origin of the symbol itself. Bring up your symbol in the symbol editor, display all layers and then do a fit view. If there is something amiss it will be quite obvious.
    Originally posted in cdnusers.org by osprey
    archive over 18 years ago
    Another area to check is the pin numbering. Do the footprint pin numbers match what is used in the schematic symbol.
    Originally posted in cdnusers.org by jlc
