  3. Pin swap by pairs
  • Subscribers 163
  • Views 13944
Pin swap by pairs
archive over 18 years ago
Hi:
I am using the ORCAD Capture - Allegro flow. I have a VertexIV FPGA, and lot of differential
pairs.  To sucessfully routed the PCB, those differential pairs have to be swapped. I don't
want pin-pin swap, since this is very easy to make mistakes. Does anybody have the idea
how can I get pair-pair swap in my design flow(with pair polarity) ? I cannot make many
homogeneous parts at schmatics side since this is not my job, it seems to me once I got this
by device file, but rightnow I keep getting error message. It will be very thankful if anybody
can give a hint on this.
Thank you in advance.
Originally posted in cdnusers.org by benbenxia
    You are looking for 'function' swap which is well documented in the OrCAD and Allegro literature.
    Originally posted in cdnusers.org by redwire
