  3. No device property found?
  • Subscribers 163
  • Views 14130
archive over 18 years ago
I've made lots of symbols before, but I have two connectors that I can't figure what's wrong.
I create the .dra, then create the .psm, then the device file.
When I load my netlist (with these symbols in it), it loads OK, but I cannot manually place the two connectors. I keep getting a "no device file found" even though I KNOW it's there and the placement window shows the connector...
Any ideas?? I'm stumped!
Originally posted in cdnusers.org by pitbull107
    Have you checked if the pins on the schematic body matches the allegro footrprint?
    Originally posted in cdnusers.org by kishore
    Yes. Several times.
    I did an experiment however, and re-created both symbols exactly like the first ones. Then I re-loaded the netlist into my start (pre-wire) board. Then proceeded to place components without a problem. NOTE: I did have to repeat this process about three times before it worked
    My guess is some bug, glitch, gremlin or Cadence flu caused the problem. If memory serves, I believe I have run into this before, but not very often.
    Cadence guys? Have you delt with this? And what causes it? BTW, I am using cersion 15.x on Win2k
