  3. How to rename a pin?
  • Subscribers 163
  • Views 15878
archive over 18 years ago
I want to rename a pin (say from "1" to "A") from a package. When I open the package (.dra file) for editing, I can't find a solution for this simple task...
Thank you for your help
  Guenther Jehle
Originally posted in cdnusers.org by guenther.jehle@entner-electronics.com
    Use Edit > Text
    Select the pin text and change it to your desired text by backspacing at the Allegro command line and then entering the text you want.
    Originally posted in cdnusers.org by Trykon
    Ok, I was too focused on the pin itself for this solution.
    Thank you!
