  3. How to oupput gerber file to my defined folder?
  • Subscribers 163
  • Views 16899
archive over 18 years ago
when press "Create Artwork" button, all gerber files be outputed to the default folder,
now i want to output gerber files to my defined folder.
how should i do? thanks!
Allegro version code is 15.7.
thanks in advance
Originally posted in cdnusers.org by watchdog1976
    First save the board file in the defined folder where ever you need.
    The Gerbers will be generated in the defined folder.
    All the best
    Sriram
    Originally posted in cdnusers.org by sriramssr
    In the User Preferences set the variable "set ads_sdart" which can be found in the "File_management" category. Set the value to the directory in which you want the artwork and parameter files (art_param.txt and art_aper.txt) to be read and written.
    Originally posted in cdnusers.org by Trykon
    thanks, i have tried it, it is ok,
