  3. Run a skill file!!!
  • Subscribers 163
  • Views 13511
Run a skill file!!!
archive over 17 years ago
hi all,
           I need to run the attached skill file in allegro, kindly guide me through the steps. I am using SPB 16.0, and it supports skill licenses.
It would be really helpful.
Thanks in advance....
Best regards
Niraj
Originally posted in cdnusers.org by nforniraj
replace_via.il
    Load the SKILL file into Allegro through the command line or through your allegro.ilinit file (See Sourcelink doc 1833005 titled "How to create an Allegro.ilinit file"). To load the file from the command line type
    skill load "replace_via.il"
    When the SKILL file is loaded a "t" should be returned.
    Execute one of the commands that are registered
    "replace via"
    "replace pin"
    "greplace via"
    "greplace pin"
    Originally posted in cdnusers.org by Trykon
