  3. Netlist error with padstack
  • Subscribers 163
  • Views 13292
archive over 17 years ago
I'm getting a error when generating a netlist that it can't find padstack.  The two parts in question have pads with unusual shapes so the pads were made by creating a dra file and ssm file then added in the geomerty as shape in the pad designer.  Would the error be because these files have a different name than the .pad file? Do my .pad, .dra & .ssm all have to be the same name for this to work?
Originally posted in cdnusers.org by gonuclear
    I use ssm shapes that have different names from the padstack so I don't think that is the issue. One problem we've seen before is if we didn't have the ssm path (not the padstack path) set properly.
    Originally posted in cdnusers.org by Randy R.
    check psmpath variable...
    Originally posted in cdnusers.org by jch teyssier
