  3. Chamfering of Corners.
  • Subscribers 163
  • Views 14711
archive over 17 years ago
Hi All In my design, I want to chamfer route keep in area with radius of 3mm for mouting hole while keeping the board outline as such in rectangular shape. But it seems command chamfer is not working on route keep in area. Is there any other trick to do it Thanks in advance.
Originally posted in cdnusers.org by Rajiv
    I got it. It is possible using shape edit boundry command. Select type arc & specify radius value accordingly.
