  3. Link Property
  • Subscribers 163
  • Views 12868
Link Property
archive over 17 years ago
Has anyone added a intranet address as a symbol's user-defined property, so you can access the component's .pdf datasheet ? If so, can you please explain the details ? I tried using the dsht.il Skill file but I the added property doesn't get listed once the component is on the board. Any help would be appreciated.
Originally posted in cdnusers.org by LRCohen1961
    Any such property is likely to be on the component definition - not the symbol.
    I use the part number property and use Skill to bring up the data sheet by requesting the user to select a component.
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
