  3. Cadence problem
  • Subscribers 163
  • Views 13628
Cadence problem
archive over 17 years ago
Hi Everybody,
   I am getting this Problem when I slide the net and right click the mouse button. This problem arrives for this board only.
Originally posted in cdnusers.org by visiontek
pro.doc
    Try DBDoctor (Tools->Database Check), if this doesn't fix the problem the brd will need to go to Cadence
    Originally posted in cdnusers.org by andrewjw
    Thanks for the suggestion
    I allready tried it but its not woking.
    regards,
    N raghuram
    We also faced the same problem. Install the latest Hotfix from sourcelink.
    Originally posted in cdnusers.org by shiva
    We had the same problem last week ... Cadence knows about the problem and has promised to fix it in the next release. The problem is with the value in the "Max 45 len:" window in the Options Tab. In your attached ".doc" file the value shown is 2147483.6. To get rid of you problem, invoke the Slide command and then change the number in that window to 9999.0 and that will fix your problem. Good luck
    Vince
    Originally posted in cdnusers.org by navigator
