  3. SKILL scripts in Orcad PCB Designer
  • Subscribers 163
  • Views 14222
archive over 17 years ago
Sorry if this is a newbie question, I've been using Orcad Layout for a while but now am transitioning to PCB Designer.  I've tried searching but didn't have any luck.
Can I use SKILL scripts in PCB Designer?  From the EMA website (www.ema-eda.com/.../pcbdesignerpspice.aspx) it claims that PCB Designer supports SKILL but if I type 'skill' at the command prompt I get an invalid command error message.
Thanks in advance...!
Originally posted in cdnusers.org by radix99
    I believe it's similar to Allegro PCB Design L in that there's no skill development / debugger environment .. hence the error you are seeing. You should be able to run skill routines by including them in the "allegro.ilinit" file that loads during startup.
    Dave
    Originally posted in cdnusers.org by dschaefer
