  3. Outline for drill chart has disappeared.
  • Subscribers 163
  • Views 13596
archive over 17 years ago
Whenever I generate the drill chart now, there is no outline. It used to generate it and all of a sudden it just stopped. The lines between the cells are there, just no outline. Silly, I know, but a pain! anyone else have this happen? Is there a way to get it back? Jackie
Originally posted in cdnusers.org by Jackie
    We see the same problem here, and I submitted an SR about the problem (V16.01 with hotfix 10). Some of the suggestions involved reverting to the original Allegro .dlt template file and possibly reducing the text font physical size. Certainly something to review, in our case the occurance is random and not resolved by the proposed changes.
    Originally posted in cdnusers.org by dschaefer
    Thank you!
    I have also faced the same problem. I just reinvoked the tool & then regenrate the drill chart. For the time being it solves the issue.
    Originally posted in cdnusers.org by Rajiv
    That' worked. Thanks!!
