  3. Selecting Multiple dbids/symbols with unique properties
  • Subscribers 160
  • Views 851
vramanan
vramanan over 15 years ago
 Hi Guys
Here is the scenario
I have a list of symbols with thes 2 properties
prop1= "prop1value1"
prop2=" prop2value1"
now the 2nd symbol in this list might have the following values
prop2=" prop2value2"
Now the question is How do I select all the symbols with prop1="prop1value1" and prop2="prop2value1"
I tried 2 different method without much success
I tried to use setof(x dblist (x->prop1=="prop1value1" && x->prop2=="prop2value1"))
and
tlist=axlSelectByProperty("symbol"  "prop1" "prop1value1") && axlSelectByProperty("symbol" "prop2" "prop2value1")
both fails to do what I want
Please help me how can I achieve this
I appreciate any help
regards
Venkata
  • kerchunk
    kerchunk over 15 years ago
    One way would be to build up a temporary list of dbids that all have the first property value, then scan this list for dbids that have the second property value.
    got_1_prop_list = nil
    got_both_prop_list = nil
    foreach( obj  mylist
        foreach( prop_pair axlDBGetProperties( obj)
            prop_name =  car( prop_pair)
            prop_value =  cadr( prop_pair)
            if( prop_name == "prop1" && prop_value == "prop1value1" then
                got_1_prop_list = cons( obj got_1_prop_list)
            );end-if
        );end-foreach
    );end-foreach
    foreach( obj got_1_prop_list
            if( prop_name == "prop2" && prop_value == "prop2value2" then
                got_both_prop_list = cons( obj got_both_prop_list)
            );end-if
        );end-foreach
    );end-foreach
    HTH,
    Chris Walters
    local Cadence guru
  • vramanan
     Hi I found a way
     Here is what I did
    list = axlSelectByProperty("symbol" "prop1" "prop1value1")
    list=setof(x list x->prop->prop2 == "prop2value1")
    regards
    Venkata
