  3. Skill to check minimum cline segment
  • Replies 24
  • Subscribers 167
  • Views 31058
Alice 2009
Alice 2009 over 15 years ago
I am trying to write an skill to check cline segment length and show DRC if it violate the minimum cline segment.
Does anyone have similar skill that I can refer? please share.
Alice.
  • PAVANRKS
    PAVANRKS over 12 years ago
    Hi Alice,
     Thank You!!!!!!!!
     Good Day
    Pavan Kumar
  • PAVANRKS
    Hi Alice,
        I Unable to run it. If i click on run botton the attomatical all layers getting switch off
    The below from file will create in directory where we saved the board file
    FILE_TYPE=FORM_DEFN VERSION=2
    FORM toolwindow
    FIXED
    PORT 44 15
    HEADER "Minimum Line Width DRC"
    POPUP <LayerCountPopup> "2" "2", "4" "4"
    TILE
    TEXT "Minimum Cline Width used in Top Layer: "
    FLOC 1 1
    ENDTEXT
    FIELD ClineWidthTop
    FLOC 32 1
    LONGFILLIN 10 15
    ENDFIELD
    TEXT "Minimum Cline Width used in Bottom Layer: "
    FLOC 1 4
    ENDTEXT
    FIELD ClineWidthBottom
    FLOC 32 4
    LONGFILLIN 10 15
    ENDFIELD
    TEXT "Layer Count: "
    FLOC 1 7
    ENDTEXT
    FIELD LayerCountPopup
    FLOC 10 7
    ENUMSET 5
    POP LayerCountPopup
    ENDFIELD
    FIELD Run_button
    FLOC 25 10
    MENUBUTTON "Run" 7 3
    ENDFIELD
    FIELD Close_button
    FLOC 35 10
    MENUBUTTON "Close" 7 3
    ENDFIELD
    ENDTILE
    ENDFORM
    Please have look on it.
    Minumcline
     Thank's
     Good Day,
    Pavan Kumar Kulkarni
  • Alice 2009
    Alice 2009 over 12 years ago
    Hi Pavan
    This SKILL is customize for  2/4layers.
    Regards
    Allice
  • PAVANRKS
    Hi Alice,
     I'm unable to retrive desired requirement for 2/4 layer also.
    Good day,
