  3. Help with lists
  • Subscribers 160
  • Views 12820
Help with lists
bulldog
bulldog over 15 years ago
Greetings all;
I'm trying to write a program to globally unmirror vias.  The code is below and I am having trouble making it work correctly.  I am trying to create a new list of just vias, without the testpoint vias, and delete it after all other vias have been unmirrored.  I'm hoping someone can help with this.  Thanks!
procedure( _unm_vias()
let(list(l_vias, via via_count rm_ncvia_count rm_1cvia_count l_nc_vias repfile l_New_Vialist)
l_nc_vias=list()
l_New_Vialist=list()
via_count=0
m_via_count=0
axlClearSelSet()
axlSetFindFilter(?enabled '(noall vias invisible) ?onButtons '(vias))
axlAddSelectAll() ;select all of the vias in the design
l_vias=axlGetSelSet() ;put the vias in a list
via_count=axlGetSelSetCount()
printf("%d vias found in the design.\n" via_count)
axlClearSelSet()
foreach(via l_vias
unless(via->testPoint
gotViaName = via -> name
gotViaLoc = via -> xy
gotViaNet = via -> net -> name
gotViaRot = via -> rotation
append1(l_New_Vialist via)
if(axlDBCreateVia(gotViaName, gotViaLoc, gotViaNet, nil, 0, nil) then
m_via_count++
);endif
);end unless
);end foreach
axlDeleteObject(l_New_Vialist)
printf("%d vias replaced/unmirrored.\n" m_via_count)
);end let
);end proc
axlCmdRegister("umv" '_unm_vias)
  • eDave
    eDave over 15 years ago
    Replace:
    With:
    l_New_Vialist = cons(via l_New_Vialist)
    See attached for some ideas to improve the code slightly.
    Cheers,
    Dave
    _unm_vias.zip
  • fxffxf
    fxffxf over 15 years ago
     If you are changing a considerable number of vias then you will want to wrap the entire operation in a axlDBCloak call. See its doc for more info.
  • bulldog
    Thanks Dave,
    You gave me the help I needed plus a better way of accomplishing my goal!
