  3. Align tool
  • Replies 14
  • Subscribers 163
  • Views 17082
Align tool
Silver John
Silver John over 14 years ago
Present to you the tools to align objects on PCB.
Welcom for comments, bugs, suggestions.
Questions?
Who wants to can join to development.
Code in the repository: github.com/.../align
Installation described in the README.md.
Issues:
Icons not works in Allegro 15.x
axlUIMenuRegister() not work in Allegro 15.x
 And how it looks:
Align tool UI
  • ConnectPCB
    ConnectPCB over 14 years ago
     I tried this, and it works great !    Only one thing, but not important.
    The  issue was on a couple of my parts I did not have a pin1, (I had pin A and K) it exited with error (Symbol "Cr54" has no pin 1.
    E- *Error* max: can't handle max(nil -1000000.0). So maybe have a pin name selection box ?   But of course when you are selecting a group of components they all won't be pin A / K ... it will be a mix of different pin numbers.    So this may not be possible.
  • Silver John
     Fixed.
    Added field for pin number/name (text field).
    If pin not found then you will got warning message, and object will be aligned/bound by body center.
  • Helen
    Helen over 14 years ago
    Currently we are using "out of the box" Allegro Align command available in Placement mode, works just fine.
    Long time ago we used my simple code with simple form but I did figured out UNDO.
    Basically you have to capture all "DOs" xy in a list to be able to "UNDO".
    See code attached
    align_sym.il
  • Silver John
     Hi, Helen. Thanks for your concern.
    But in your script "undo" for only the last action, and only in the script. I implemented the "Oops", by using standart axlDBTransactionXXXX  functions.
    I was referring to a global, external mechanism UNDO. We recently discussed this problem (http://www.cadence.com/community/forums/T/19737.aspx), and the solution is not visible.
      PS Yes, I also used a standard command Align, some scripts other authors...  Then wrote my own script.
  • Ejlersen
    Ejlersen over 14 years ago
     Hi
    axlUIMenuRegister() was new in 16.3 and will hence not work before that.
    Don't know if it was updated into 16.2 / 16.01 /16.0 ISR stream, but sure it was not added to 15.x
    Regards
    Ole
